DEFIV Differential Lock-Down DIY
02-19-2013, 08:57 PM | #1 |
DIYER
614
Rep 5,521
Note: Not responsible for any damage to you or your car,
this worked on my car so will work on yours. Thi kit as been tested over and over countless hours by Rick@DEFIV. If it doesnt fit you did something wrong. ***This tutorial assumes you know how to get your car secured on jack stands, if in doubt do NOT attempt this DIY! Suggestions: Do NOT use a torch to remove bushings, it is not needed and can deform subframe amd make install of bushing appear off...they are with in .001" tolerance. They fit PERFECTLY. Notes: *I assume you know how to take exhaust, panels ect off. **The design off this product is the copyrighted by Rick@DEFIV. ***You can use a hole saw to pull out bushings instead of pipe if needed. Here is the work of art, this kit really impressed me with how close everything fit....I can't imagine the testing involved to get this to spec. Rick Has some of the best customer service in this bussiness period! [/B]Removal of differential (I had mine out for wavetrac so I took as many pics as I could):[/B] Removal of "Front" (smaller)bushings: Removal of "Rear" (larger) bushing Installing bushings Installing Diffetrential/half shafts and driveshaft back in car, some steps are left out since it is basically reverse order: Note on driveshaft installation: Tighten in order below! A. Insert nut B. Guibo C. Center support bearing 4th link bushing installation: I hope this is of help to you guys!
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-28-2013, 09:57 PM | #3 |
DIYER
614
Rep 5,521
03-20-2013, 08:47 PM | #5 |
DIYER
614
Rep 5,521
03-24-2013, 12:04 AM | #6 |
driver mod in progress
225
Rep 1,858
Drives: with both feet
Legit write-up! Thanks for taking the time to educate the rest of us.
03-24-2013, 01:12 AM | #7 |
DIYER
614
Rep 5,521
thanks man!
03-24-2013, 04:06 PM | #8 |
17
Rep 575
Be careful with the part number for the Guibo bolt's nuts. He lists a 'kt' at the end however the parts number did not pull up for me. Just remove the 'kt' and it will give you what you need.
Thanks for the thorough write up |
03-24-2013, 04:25 PM | #9 |
DIYER
614
Rep 5,521
weird, I read them right off the pkg.
05-01-2014, 04:37 PM | #10 |
Black on Black on Black.
38
Rep 532
These are 10% off if you email them.
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV |
06-15-2014, 10:30 PM | #11 |
24
Rep 273
im sorry to revive this but what exactly is this??? is it like having an lsd?? or does it only take away wheel hop???
06-19-2014, 09:00 AM | #12 | |
36
Rep 419
http://www.defivfabrication.com/n54.html |
08-18-2014, 04:36 PM | #13 |
148
Rep 965
Drives: e92 m3
Bumping thread
Do you suggest subframe bushings n rear sway bar along with LSD install?
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
