05-25-2011, 10:12 PM | #111 |
11818
Rep 23,187
just got this from circle bmw and doing install tomorrow and coding on saturday.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-26-2011, 01:21 PM | #112 |
11818
Rep 23,187
finished install today super easy. took about 30 minutes. should have done this a long time ago. only hard part was lining up the plastic siren mount to the holes blind and starting the threads. all in all a very easy install thanks to this thread.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| Last edited by 1MOREMOD; 05-26-2011 at 06:46 PM.. |
07-30-2011, 03:19 AM | #113 |
Rep 57
I didn't have to activate...
thanks MDCTFTW for the great DIY
I just did this installation on my 09 e90 m3 and the alarm works right after the installation. See video below what does the activation get you? |
07-30-2011, 10:04 AM | #114 |
440
Rep 2,373
Activation will activate the alarm system in your car and will change VO ... also you will have an option on idrive to turn on / off the sound confirmation when you lock/unlock the car ...
08-06-2012, 02:00 AM | #117 |
123
Rep 1,973
Only if you like to follow instructions
MDCT ... so you can drive and eat a hamburger at the same time. |
09-06-2012, 01:31 AM | #118 |
IG: limited.slip
338
Rep 1,927
Great thread!
Can someone share the part number for the OE alarm retrofit kit? Also is there a different kit depending on the car's MY? My 2010 has no hood switch (my 2008 did!) so I need whatever kit that includes that. TIA Edit: For the sake of grouping all the info into one thread: Cars built before 03/2009 -> part number 65120403658 Cars built after 03/2009 -> part number 65120399635 More info for the later cars HERE Some will need a new mirror (clown nose), door lock etc. Last edited by kaiv; 09-06-2012 at 02:04 AM.. |
10-03-2012, 11:11 AM | #120 | |
23
Rep 344
Nice DIY. Installed the alarm a couple of weeks ago and finally got around to the coding this past weekend.
Did the coding myself and it was very simple. Add +K302 to your VO in both CAS and NFRM. After that use expert mode profile to code your DWAI, DWAS, CAS and CAPPL (if you have Idrive) modules to defaults. I you're like me and had previously coded your CAS and CAPPL modules and don't want your changes overwritten then code DWAI and DWAS to defaults and change the following values in CAS and CAPPL. Quote:
03-15-2013, 10:07 PM | #123 |
Rep 13
Second Hand Parts?
Has anyone found a source for second hand alarm parts? I imagine that some E9x cars are starting to find their way into salvage yards as insurance write offs.
03-28-2013, 12:10 AM | #124 |
15
Rep 255
I installed this and the horn screws for the lid under the chassis is a real pain in the rear. It took me a while to line up the two screws. Other than that it was a breeze.
Thanks OP.
2008 E90 M3 SPARKLING GRAPHITE METALLIC
03-28-2013, 12:11 AM | #125 |
11818
Rep 23,187
yep thats a real PITA.
06-07-2013, 10:33 PM | #126 |
24
Rep 422
Anyone doing this DIY lately? What's the best price out there?
2006 E85 Z4 3.0si
2015 F10 535i M Sport Sold 2011 E92 M3 Sold 2007 E90 335i Sold 2006 E90 330i Sold |
08-25-2013, 02:21 AM | #127 |
18
Rep 129
Drives: '09 E92 328i
subscribed
08-25-2013, 09:56 AM | #128 |
11818
Rep 23,187
talk to circle bmw in jersey. i get lots of god deals there or bryan at winslow in colorado springs who is a member here.
09-01-2013, 10:21 AM | #129 |
11818
Rep 23,187
no coding wont do it you will have to buy the motion sensor unit and siren as indicated throughout the thread.
09-09-2013, 09:45 AM | #130 |
23
Rep 344
You need to buy the alarm kit, install it and then do the coding. Check out the coding section on e90post....that'll get you started.
09-11-2013, 11:49 PM | #131 | |
Rep 45
http://www.ebay.com/itm/121142026340...84.m1497.l2649 Waiting for it to come in so I can install. I have an 08 pre-wired. |
09-12-2013, 03:27 AM | #132 | |
Peanut Butter Jelly Time
21
Rep 199
Let us know how it turns out, I've got one on the way as well. |
