2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Fault codes misfire
      04-21-2024, 01:02 PM   #1
charlie2000
Drives: Bmw 2 series 218D
Hi all,
New to the forum and looking for a little bit of advice. I have had an engine management light on and off now for about 3 months. Upon starting up this week it came up with drivechain fault all in red on the dashboard. Engine starts and runs fine on tick over but as soon as you rev it runs rough and splutters.
Had it plugged into ISTA on a friends laptop as I don’t have the software and the following codes come up:
- 282E00 - Oxygen sensor after catalytic converter, heating, activation: Short circuit to B+
283300 - Oxygen sensor before catalytic converter, heating, activation: open circuit
282D00 - Oxygen sensor before catalytic converter, heating, activation: Short circuit to B+
283400 - Oxygen sensor after catalytic converter, heating, activation: Open circuitOxygen sensor after catalytic converter, heating, activation: Open circuit
270100 - Hot film air mass meter, signal: Too low
Rang my local dealer and the soonest they can see the car is 3 weeks time so going to try and tackle it myself if it’s a sensor.
Looked on the OBD Scanner and seems:
O2 Lambda sensor bank 1 sensor 1 -0.99V
O2 Lambda sensor bank 1 sensor 2 - 1V
O2 Lambda Sensor bank 2 sensor 1 - 0V
O2 Lambda Sensor bank 2 sensor 2 - 0V
Noticed on the sensors that the MAF air flow rate was - 0g/sec
Any ideas what I should look at first could it be a faulty MAF sensor?
Not into massively into mechanics but want to try and give this one a shot!
Thanks
      04-24-2024, 09:01 AM   #2
Adam Lanister
Drives: Bmw m2 2018
Originally Posted by charlie2000 View Post
Hi all,
Thanks
check the wiring for both the MAF sensor and oxygen sensors. Look for any signs of damage, corrosion, or loose connections and try to repair them !
If I was in your shoes I would take it to a local shop
      04-24-2024, 06:36 PM   #3
Shirazkhan
No_Country
28
Drives: bmw
Fault codes are saying open circuit.Live data is showing 0v on bank 2 sensor 1 and 2.Check the wiring to those sensors,wires might be damaged.
Search this Thread:
Advanced Search
2addicts
