04-11-2024, 08:11 AM | #1 |
Rep 16
(Guide) F40/F44 Ambient lighting color change(BimmerCode)
Since i got bimmercode i have looked everywhere on how to change the ambient color on my 2 Series GranCoupe.
On bimmercode you can change the bronze to a few colors in basic mode. But i wanted to add a few more. i loooked up some guides online but they are for g20 models. So i went into expert mode and found all the bytes myself and would like to share my findings Guide Connect to bimmercode Click on BDC Expert mode Search for LIC_LCI_COLOR_LIBRARY_DATA Search for LIC_LCI_COLOR_PROFILES_DATA Go to Custom values at the Bottom Now you will need to change the bytes using RGB hex codes (just use googles hex code) Once you have your 6 digit hex code go to the bytes below and change the value White Door cards Byte 3 Byte 4 Byte 5 Roof light Byte 8 Byte 9 Byte 10 Bronze Door cards Byte 13 Byte 14 Byte 15 Roof lights Byte 18 Byte 19 Byte 20 Orange Door cards Byte 23 Byte 24 Byte 25 Roof lights Byte 28 Byte 29 Byte 30 Blue Door cards Bytes 34 Bytes 35 Bytes 36 Roof lights Byte 39 Byte 40 Byte 41 Green Door cards Byte 43 Byte 44 Byte 45 Roof lights Byte 48 Byte 49 Byte 50 Lilac Door card Byte 53 Byte 54 Byte 55 Roof lights Byte 58 Byte 59 Byte 60 Once done code it. You can have two different colors for the door card and roof lights Last edited by Z-_Hamza_-Z; 04-11-2024 at 08:20 AM.. |
