01-25-2021, 10:43 PM | #1 |
Global Moderator
6389
Rep 2,309
Drives: E90 M3 6MT
Introducing the First-Ever BMW M5 CS!
Featured on BIMMERPOST.com BIMMERPOST NEWS Introducing the All-New BMW M5 CS BMW M5 CS Facts • The quickest and most powerful BMW production vehicle ever. • 627 hp and 553 lb.-ft. of torque. • 230 lbs. lighter than M5 Competition. • 0-60 mph in 2.9 seconds. Top speed of 190 mph. • MSRP of $142,000 plus $995 Destination. • Production begins March 2021 & limited to one model year only (2022). • U.S. cars expected to arrive 2nd half of 2021. January 26, 2021 Woodcliff Lake, NJ- BMW is proud to announce the quickest and most powerful production BMW car ever, the 2022 M5 CS Sedan. The new limited production super sedan builds on the immensely capable M5, itself recently updated for model year 2021, by delivering more power, greater performance, lighter weight and exclusive interior appointments making the new M5 CS truly a one-of-a-kind vehicle in its class. Power and Drivetrain The S63 4.4-liter M TwinPower turbo V8 has been tuned to deliver 627 hp at 6,000 rpm, an increase of 10 hp over the Competition model. The torque band delivers its full 553 lb.-ft from 1,800 to 5,950 rpm, 90 rpm wider than the M5 Competition. The eight-cylinder’s engine redline is 7,200 rpm. The high-pressure direct fuel injection ensures precise fuel atomization and fast engine response. The liquid-to-air intercooling for the two turbochargers and oil system with two pumps make sure that the M5 CS is as competent on track as it is on the street. Combined with the reduced vehicle weight, the high levels of power and torque and working through the 8-speed M Steptronic automatic transmission with Drivelogic and the M xDrive allwheel drive system, the M5 CS reaches 60 mph in just 2.9 seconds, 0.2 seconds quicker than the M5 Competition model. Top speed with the standard M Driver’s Package is 190 mph. The M Driver’s Package also includes a voucher for BMW driver training. The rear-biased M xDrive all-wheel drive system distributes the available 553 ft-lbs. of torque between front and rear axles via an electronically controlled multi-plate clutch while the Active M Differential further optimizes power between the rear wheels for maximum grip and lateral dynamics. The driver can select from three xDrive modes including 4WD, 4WD Sport and 2WD. The Dynamic Stability Control system can be adjusted between three settings to further enhance driver control – DSC ON, MDM (M Dynamic Mode) and DSC OFF. The eight-speed M Steptronic transmission provides extraordinarily short shift times and fast, precise responses to every input of the accelerator. The Drivelogic switch on the gear selector lever allows three modes - efficient, sport or track with extremely rapid gearshifts. A transmission oil cooler ensures the transmission operates within its best temperature range even when the car is put through its paces on a closed track. Exhaust system and M Sound button
Chassis tuning The M5 CS builds on the very high dynamic abilities of the M5 Competition Package’s chassis and suspension tuning. This means stiffer engine mounts (5,139 lb/in vs. 3,312 lb/in) than the standard M5 Sedan, 10% firmer springs, 0.2-inch lower ride height, increased front negative camber, a firmer rear anti-roll bar and tow-link ball-joint mounts. The M5 CS receives further spring and Dynamic Damper Control tuning over the M5 Competition to take advantage of the lower vehicle weight and of the optionally available (no-cost) Pirelli P Zero Corsa tires. Standard mixed-size non-runflat performance tires measure 275/35R20 at the front and 285/35R20 at the rear and are fitted to Gold Bronze 20-inch M forged Y-spoke wheels - 9.5 J x 20 in front and 10.5 J x 20 in the rear. Pirelli P Zero Corsa performance tires are available as a no cost option and make full use of the M5 CS’s enhanced handling capabilities for those looking to experience their new sedan in a closed track environment. The standard Dynamic Damper Control and M Servotronic steering offer a choice of electronic drive modes – COMFORT, SPORT and SPORT+. COMFORT focuses on everyday usability combined with standout dynamics. SPORT mode reduces wheel and body movements to create more direct contact with the road, but still has sufficient comfort dialed in. This setting is suited perfectly to sporty driving on twisty roads and offers the ideal handling balance for laps of the Nürburgring’s Nordschleife. SPORT+ mode maximizes dynamic performance on smooth asphalt allowing the driver to sense the connection with the road surface acutely, making it the best setting for dedicated closed race tracks. SETUP button takes drivers straight to the configuration menu Pressing the SETUP button positioned takes the driver to the 12.3-inch central display’s menu for programming an individual configuration for the powertrain and chassis options. This allows drivers to tailor the car’s setup to the driving situation at hand and to their personal preferences. Simplified operation using the touchscreen display or iDrive Controller makes it easy to choose different settings for the engine, suspension, steering and M xDrive system. The two, red painted M1 and M2 buttons next to the gearshift paddles on the M Alcantara steering wheel make it possible to change quickly between setups. Drivers can use these buttons to compose two individual setups with their choice of M xDrive, DSC, engine, transmission, chassis, steering and braking characteristics, as well as their desired M View configuration in the HeadUp display. M View configuration The driver can toggle swiftly between the ROAD, SPORT and TRACK settings using the M Mode button. Keeping the M Mode button pressed, then confirming the prompt in the central display engages TRACK mode. When M View is active, a prominently positioned tachometer with color-coded warning zones appears in the Head-Up display, while shift lights indicate the ideal time to change gear. Navigation instructions, distance warnings, the current gear, the vehicle speed, and any speed limits or overtaking restrictions detected by the Speed Limit Info system are also shown here. Default ROAD mode – all standard and optional driver assist systems are fully operational. Full information displays in the digital instrument display and Head-Up display. SPORT mode – Allows the driver to adjust or turn off various assist systems. The M View is activated for both the instrument cluster and Head-Up display. A tachometer, digital speed, selected gear and shift lights are displayed in the center with coolant temperature, tire pressure and longitudinal and lateral forces available to the side. TRACK mode – Designed for use on closed tracks, confirmation of this mode is required via the iDrive controller. Driver assistance system intervention is turned off. The audio system and center control display are turned off so the driver may concentrate on the road ahead with important information provided via the Head-Up and the digital instrument displays. Exterior design and extensive use of carbon-fiber Exterior CFRP components include:
Exclusive interior appointments
Exterior colors Standard:
Standard M Carbon ceramic brakes
Full List of Standard Equipment
Options Stand-alone options for the M5 CS include:
Gallery Videos
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
28
INDVDL///M810.50 AlexFL7844.50 F32Fleet3636.50 m20e30871169.00 X5MMMMM31.00 Milas29.50 oz555674.50 Holset278.50 X54TH903.50 AndrewC198910949.00 khanyam4803.00 em4ef82102.50 jayteeeeeeeee0.00 MadBimmeRad7124.50 m3less130.00 MR M2C0.00 JTO245279.00 ///M2_MA87.50 ellipsis2121623.50 Hedoniste3883.50 F80DK391.00 Niko ZV118.00 willjames710.00 emescopa31.50 dappercivility203.50 02M3ForMe4278.00 Jose Lopez0.00 1dopem567.00 |
01-26-2021, 04:56 PM | #2 |
5459
Rep 7,037
230 lbs ligther than the M5C! That’s serious weight reduction.
I love everything about it, just wish I had a $143k + markups budget. |
01-26-2021, 05:05 PM | #3 |
Global Moderator
6389
Rep 2,309
Drives: E90 M3 6MT
Watch M CEO Markus Flasch introduce the all new BMW M5 CS
solstice5459.00 Jose Lopez0.00 |
01-26-2021, 05:05 PM | #4 |
Ring Leader of G8X Haters
25175
Rep 8,769
Looks good, love that they are finally adding more green to the lineup.
Price isn't as bad as I thought it'd be either (pretty much equivalent to M8GC). Hopefully the driving dynamics and feedback have been decently improved. |
GERMAN M34182.00 LSM1118.00 santamonica0070.00 MR M2C0.00 BMWFLYNN54.00 JTO245279.00 Simple1133.50 Jose Lopez0.00 |
01-26-2021, 05:09 PM | #5 |
25175
Rep 8,769
Also for a car with the Nurburgring on its headrest shouldn't they reveal its time?
01-26-2021, 05:09 PM | #6 |
Truth seeker
811
Rep 566
Drives: German cars
Completely superficial but...
Anthracite alcantara headliner - yes please! Reminds me of our e39 m5 days! Headrests are a neat touch Also, yes to the wheels. Much better IMHO than the G8x platform offering. |
F32Fleet3636.50 ThugzZ BunnY681.50 bngcruiser277.00 Swappy539.00 FMLYSDN1183.00 335iMIAMI25.50 MR M2C0.00 e30m300.00 |
01-26-2021, 05:11 PM | #7 |
10873
Rep 27,644
wow
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
audioMeth222.00 |
01-26-2021, 05:13 PM | #9 |
10253
Rep 8,679
I like it... but who is the target customer for a 5 series w bucket seats?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
17
stein_325i25175.00 ra2289308.50 BigHunk269.50 335iMIAMI25.50 jas159899.50 Deleted Account144.50 thaalrasha621.00 JTO245279.00 city1991231.00 Swappy539.00 notyourdadsf86164.50 mcman19.00 sharocks359.50 AtlantaDude128.00 sittingmongoose627.00 aque0us13.00 335xs2dinan141.00 |
01-26-2021, 05:13 PM | #10 |
426
Rep 379
Drives: 2021 X7 M50i, 2021 Porsche Cay
This is 🔥 Love it!
DrivenByE30595.00 |
01-26-2021, 05:13 PM | #11 |
989
Rep 1,807
01-26-2021, 05:14 PM | #12 |
1743
Rep 3,205
Too bad I use all five seats in my M5 or this would be a possibility. I do want that hood though. |
whatnotsomuchf80247.50 StealthM590.50 |
01-26-2021, 05:14 PM | #13 |
203
Rep 200
Just Wow 😍
DrivenByE30595.00 |
01-26-2021, 05:14 PM | #14 |
2792
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
YES I want one.
01-26-2021, 05:16 PM | #16 |
4067
Rep 4,988
Rear buckets...lmao
Cool spec though!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-26-2021, 05:18 PM | #17 |
682
Rep 1,155
Ok I need to see an M8 CS now..... like right now.
01-26-2021, 05:19 PM | #18 |
92
Rep 122
Drives: BMW 540i
This is what a BMW is supposed to look like!!
Swappy539.00 ///M4TT150.00 Germanauto9747.50 INDVDL///M810.50 DrivenByE30595.00 Hedoniste3883.50 cbertels1215.50 scotty_g12.00 KZEVO191.00 |
01-26-2021, 05:20 PM | #19 |
BMW forever!
1395
Rep 2,428
Amazing, this is what I'm talking about!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
Swappy539.00 DrivenByE30595.00 |
01-26-2021, 05:20 PM | #20 |
3772
Rep 2,700
Those rear seats scream ring taxi !!
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
01-26-2021, 05:20 PM | #21 |
2176
Rep 4,118
After seeing this monster you could think the G8x is made by some other company but not BMW! Well done BMW, well done!
14
01-26-2021, 05:22 PM | #22 |
398
Rep 357
Drives: 2018 M2 Road & Track Build
Wow! Those G80 carbon fiber bucket seats looks right at home in the F90!!!
5100lb/ft vs. 3200lb/ft stiffer engine mount is gonna make the car feel insane Tho I doubt many of the M5 CS owner will take it on track If you have the chance to get one, pls do! |
