05-24-2020, 10:22 AM | #1 |
16
Rep 49
2016 750i tuning recommendation
I should have investigated this further before buying a Burger JB4 N63tu tuner. I did not realise my 2016 750i was speed limited to just over 130mph. I never installed the Burger tuner due to other priorities so now I am looking for another answer from ECU flashers. I am not looking for anything that will compromise the excellent daily driver sophistication of the great N63 motor. This car gets nearly 28.5 MPG on the highway using the cruise. What I do want is the speed limiter removed and more full throttle performance without reliability problems. Any suggestions from those with experience??
05-24-2020, 01:14 PM | #2 | |
Hide! My wife's coming!
814
Rep 2,816
Increased HP from 450HP to 580HP per the tuner. I personally haven't dyno tested to find out but the car is no joke. Increased throttle response in all modes Almost no turbo lag Speed limit removed Maintained stock drivability Maintained stock fuel efficiency I personally drive mixed highway and city, I am averaging 17.9mpg which is what I was getting before the tune. On long highway trips I got 28-29mpg. I highly recommend a tune over a piggy back any day. The piggy back increases boost and forces the cars system to adjust fuel/air/timing/ignition which sometimes isn't as efficient as sometimes the system maxes out and can no longer adjust. A tune on the other hand adjusts all the parameters to accommodate the additional power. The car will run more efficiently, better power, and most reliable. I am running the tune from DME tuning. They are very popular in the BMW world. I had their stage 3 tune in my F10 M5 for roughly 50k miles before selling. My buddy has 100k miles on his tuner car. The g12 7 isn't really a popular platform to mod so you don't see a lot of tuned 7s. Hard to understand how reliable a tuned G12 is. Not many with high mikes either. That's why personally went with a stage 1. It's perfectly balanced and not pushing the internals too hard.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
05-25-2020, 07:24 AM | #3 |
16
Rep 49
Thanks for the reply. Did you do yours with the mail order tune through the OBD port?? 2nd question: Does this flash have a provision to return to the stock tune if you are going in for dealer service?
05-25-2020, 09:19 AM | #4 | |
814
Rep 2,816
Once he loads the software on your system, he can show you how to return it back to stock if needed. It's a 15 minute process to flip between stock and tune. Personally, I've never switched back to stock for routine maintenance or minor warranty issues. Never on any of my BMWs. They only check when there is a major issue. Even then, it's not detectable during basic diagnosis.
05-25-2020, 11:12 AM | #5 | |
16
Rep 49
05-28-2020, 12:55 PM | #6 | |
16
Rep 49
05-28-2020, 01:55 PM | #7 | ||
814
Rep 2,816
I agree, totally different cars.
10-14-2020, 07:27 AM | #10 |
16
Rep 49
I went ahead and ordered the cat delete down pipes and will be ordering the stage 2 tuning upgrade from DME. Not sure how much additional performance I will get but nothing ventured nothing gained. Should be interesting. I am going to install the stage 2 tune first and later install the cat delete pipes to see how much each contributes.
10-14-2020, 08:17 AM | #11 | |
814
Rep 2,816
10-18-2020, 09:20 AM | #12 |
16
Rep 49
I sent a e-mail to Mo asking if I could install the downpipes first and then tune later to see what the effect each individually would have. He replied that the pipes alone would cause the car to throw a code. He says they can configure the stage 2 tune for the catless downpipes. Still waiting on the downpipes which are scheduled for shipment the end of this month. I never did get an answer from Mo on whether the stage 1 tune had enough flex to allow for the downpipes (except that it would throw a code). He did not recommend going to a colder plug for the stage 2 tune, just change them every 8000 miles.
Thegenerall0.00 |
11-26-2020, 06:43 PM | #14 |
16
Rep 49
I have been exceedingly happy with the DME stage 1 tune. Performance is outstanding and the fuel efficiency is same as stock. I have put 1,120 miles on the car since the tune which is all in town (secondary roads and expressway) and the car is averaging 21.6 MPG.
11-27-2020, 08:49 AM | #15 | |
109
Rep 399
11-27-2020, 10:11 AM | #16 |
16
Rep 49
Increased boost for sure. I didn't get any detailed information when I asked. My mileage may not be typical. I don't drive aggressively around town, but when I want to firewall it I do. One short run from 70 to over 160 MPH took place on a empty expressway early one morning. I say over 160 because although the speedometer stops there the RPM continued to climb.
11-27-2020, 05:36 PM | #17 | |
814
Rep 2,816
Increased boost is the easiest way to make power on these cars. Increase boost paired with air/fuel/timing/ignition so the car runs efficient. Alpina changed the components to ensure proper cooling and turbo efficiencies but mostly to maintain long term reliability. Increased boost creates heat and heat in turn without proper cooling will increase IATs and pull timing. You lose power. I imagine if we were to do a couple head to head pulls between a tuned 750 and an alpina you'll find the alpina will run cooler and maintain more power.
11-27-2020, 07:02 PM | #18 | |
16
Rep 49
11-27-2020, 09:17 PM | #19 | ||
814
Rep 2,816
Here is the full list of options available. https://www.bimmercode.app/cars/g11/
11-28-2020, 08:33 AM | #20 | |
109
Rep 399
11-28-2020, 08:37 AM | #21 | ||
814
Rep 2,816
11-28-2020, 09:12 AM | #22 | |
109
Rep 399
"The headunit has to be in its original state. If you used a third party solution to enable CarPlay or the navigation has been unlocked, these changes have to be reverted, because BimmerCode will not allow coding the headunit otherwise. Retrofitted iDrive systems may also not be accessible under certain circumstances." Last edited by jlin101; 11-28-2020 at 09:41 AM.. |
