11-11-2021, 12:10 PM | #133 |
142
Rep 296
mixmasternick1.50 F40 120d6.00 |
01-05-2022, 08:05 AM | #134 |
11
Rep 62
I started a new post, had loads of views but no responses.
Does anyone know if it's possible to code in the M-Display rev counter in the HUD of the F40? There seems to be success over on the G20 and G01 pages but little info here. I have bimmercode installed which I used on my F80 but will need to get a new cable/dongle or should I move to Esys? Thanks |
01-23-2022, 02:04 PM | #136 | |
Rep 22
Sport mode in ASD HU_MGU - CAFD_00003E52 - DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND - Ausgelesen = enabled (was disabled) - DISPLAY_CONFIGURABILITY_ENGINE_SOUND - Ausgelesen = aktiv (was nicht_aktiv) |
02-14-2022, 08:44 PM | #138 |
17
Rep 118
F44/F40 BimmerCode Angel Eye Brightness Coding
Hey everybody, the F44 forums are not as active as the F40 so I apologize that I’m posting here about my F44, but regardless I have a 2022 228 I XDr., full version of BimmerCode, and an enet cable. I have always coded my angel eye brightness on my previous BMWs and my mini coopers to 100% when the low beam is on, default is like 49%.
It is such a drastic difference and it really improves Visibility and looks badass, however under lighting in the body domain controller that option is absent. Does anyone know how I could go about this, is there a setting under expert mode perhaps? Thank you everyone I sincerely appreciate it👌💯🙏 |
06-30-2022, 09:27 AM | #139 |
99
Rep 334
A small change that may remove a minor irritant for somebody. When you open the rear hatch it goes to a position that can be set to one of five heights in the MMI. I found that position 3 was just about OK, except that the door would be stopped by my extending ladder suspended on hooks above the car, and I had to wrap a towel around the ladder to protect the door. The real solution is to recode the height, using BimmerCode Expert or E-Sys.
In the HKFM ECU, section 2004, there are five settings HKL_MMI_POSITION1 to 5. These are assigned hexadecimal values representing the % of total motion, from x0D (13%) to x64 (100%). I reset my POSITION3 from x57 (87%) to x52 (82%) and the door now stops just short of the overhead ladder. To avoid confusion, this is for my F40 M135i Xdrive with electrically operated tailgate. Last edited by cjn; 06-30-2022 at 09:36 AM.. |
07-11-2022, 07:34 AM | #140 | |
18
Rep 11
Bimagod0.00 |
07-15-2022, 02:19 AM | #141 |
Rep 10
12-08-2022, 04:51 AM | #143 |
Rep 15
Hello, I codified the instrument panel of my f40 with bimmercode, I put the M series, but I don't know why the 3.0 csl writing appears to me. Has this happened to anyone else?
12-08-2022, 05:52 AM | #144 |
1150
Rep 560
Isn't there a separate setting where you can choose what kind of logo is displayed?
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue |
01-07-2023, 01:29 PM | #147 |
Rep 21
Hi guys!
Does anyone know how to coding F40 so that the button to turn off the lights works?? It is always activated automatically with engine start. I refer to this video but with satisfactory result: Thanks! |
01-07-2023, 04:00 PM | #148 | |
99
Rep 334
BDC 3501 OFF_IN_PWF_ERFAHREN_ERLAUBT nicht_aktiv ==> aktiv Allow exterior lights to be turned off when engine is running |
01-08-2023, 10:16 AM | #149 |
Rep 21
01-08-2023, 11:56 AM | #150 | |
99
Rep 334
"Exterior lighting switch-off allowed" (Allow the exterior lights to be turned off when the engine is running.) It's probably the same as the expert mode I quoted. I have never used this feature so I can't guarantee that it works. |
01-09-2023, 12:21 AM | #151 | |
1150
Rep 560
01-09-2023, 02:19 AM | #152 |
448
Rep 849
01-09-2023, 05:10 AM | #153 |
1150
Rep 560
On my G82, it only affects the headlights, the angel eyes stay on.
01-09-2023, 09:24 AM | #154 |
448
Rep 849
