03-15-2012, 12:34 PM | #45 |
22
Rep 428
I'm digging the Anthracite for my IB Z4M....or hyper?
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet |
03-15-2012, 10:08 PM | #46 |
Rep 31
Drives: 2005 Z4 3.0i
Did anyone get 17x8.5 for a square setup on a lowers non-m z4?
My only concern is they are half an inch wider than stock of 17x8. Will that stretch the 225's a little? Would it be better to run a 235 on this wheel setup? |
03-16-2012, 08:43 AM | #47 | |
2304
Rep 12,570
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
Thing with 225 is even if it's not stretched, you're not leaving yourself a lot of rim protection and you'll find yourself curbing those new rims pretty quickly. |
03-16-2012, 12:43 PM | #48 | |
Rep 31
Does anyone know an appropriate offset for these 17's with 235s? Is the et40 on the first post just the max or is that the recommended offset for 17x8.5? I'm on a lowered (dinan) setup with stock camber (-.7) up front and about -2.1 in the back, if that helps Thanks in advance! |
03-16-2012, 01:18 PM | #49 | |
2304
Rep 12,570
03-16-2012, 01:24 PM | #50 | ||
446
Rep 1,659
The most conservative setup I would run on the non-m Z4 is 245's on 17x8.5's.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
03-16-2012, 05:42 PM | #51 | |
Rep 31
Thanks once again, awesome looking wheels. |
03-16-2012, 08:06 PM | #52 |
Rep 9
That would be great! Thanks!
03-17-2012, 07:36 PM | #53 | |
446
Rep 1,659
45% of 225mm is very similar to 40% of 245mm. There is only a 1% difference it height between the two tires which is more than acceptable in a tire size change. 245/45/17 in comparison is almost 3% taller than stock.
12-31-2012, 05:16 PM | #55 |
1445
Rep 2,662
Front wheel and tire fitment is very similar to the Z4M but the rear wheel and tire fitments are more conservative. Generally the front can take a 17x8.5" ET40 with a 235/40/17 tire as a direct fitment. A 17x9" ET42 can also be used in the front with a 245/40/17 tire but anything much wider will require negative camber and a wheel spacer to clear the front strut. The 17x9" ET42 can be used in the rear as a square set up or the widest rear wheel you can use is our 17x9.5" ET35 with a 255/40/17 tire as a staggered fitment. There are a couple other variations of the 17" wheel fitment that can also be done.
01-07-2013, 08:09 PM | #56 |
146
Rep 258
Joe,
I've got a stock non-M 2.5i I've owned since new 2003 and am impressed with your wheels. Truthfully, mine has always been a street-only ride and I'm looking at 18" diameter. What setup would you recommend and does tire size affect availability and options when buying rubber? Also, would you recommend the ARC-8 or EC-7 for a street Z4? I really don't understand the difference between the two. Thanks! |
01-14-2013, 11:49 AM | #57 | |
1445
Rep 2,662
The ARC-8 is usually a couple lbs lighter per wheel and has straight spokes compared to the EC-7's curved spokes. If you were to go with the EC-7's I would suggest an 18x8.5" ET35 front wheel with a 235/40/18 tire and an 18x9.5" ET43 rear wheel with a 265/35/18 rear tire. The 18x9.5" ET43 is a new size to us that is a higher offset 9.5" wheel allowing you to use wider rear tires than with the ARC-8 wheel. If you were to go with the ARC-8's than I would suggest an 18x8.5" ET38 front wheel with a 235/40/18 tire and an 18x9.5" ET35 rear wheel with a 255/35/18 rear tire. The ARC-8's lower offset limits your rear tire width but the wheels would be lighter overall.
04-04-2013, 09:28 AM | #58 | |
Rep 45
I have a 2003 2.5i non m, and non sport. Already have the ARC-8's 18x8.5" ET38 front, and 18x9" ET42 rear. I have Hankook Ventus V12's 225/40/18 on the front, and 255/35/18 V12's on the rears. Since then I installed HR coilovers and lowered the car. The way it sits now there's no rubbing. I would like to replace the tires with Ventus V12's 235/40/18 front and 265/35/18 rears. In your products detail for non M's it says that the 235/40/18 can be used in the front and 265/35/18 can be used in the rear depending on the tire. Do you think there may be an issue because the car was lowered? The coilovers are adjustable so I can make changes as needed. thanks |
04-04-2013, 12:19 PM | #59 | |
1445
Rep 2,662
04-04-2013, 12:51 PM | #60 |
380
Rep 4,320
Drives: '07 Z4 M Coupe
I'm ready to pull the trigger on a set of ARC-8s and PSS tires, but still unsure on a few things.
Love the look of GothM's car here. I'm on H&R springs too, so assuming the F: 18x9 et42 245/40/18 and R: 18x10 et25 275/35/18 combo would work and won't rub - without the need for spacers or additional camber? When I install coilovers/camber-plates next year, can I keep these same wheels? GothM mentioned he uses a 15mm spring pad. Anyone know where can I pick these up? What length valve stems will I need for the new wheels? 36111095375 / 36146792829 43mm (RDV 001) 36111096449 / 36146792830 48mm (RDV 002) 36111095374 / 36146792828 49mm (RDV 003) 36111095373 / 36146792827 51mm (RDV 004) Besides the ability to rotate; what are the advantages of the square setup?
04-04-2013, 01:22 PM | #61 | |
1445
Rep 2,662
When going to a square set up most people usually have the camber plates already installed on the car so they can fit much larger wheels and tires up front than they would with a car with stock negative camber. The 18x9" ET42 with a 245/40/18 tire is the widest combination we can make work on the front of a Z4M with out additional negative camber. Once camber plates are installed than you are able to use an 18x9.5" ET35 in the front with a 265/35/18 tire. Grip is greatly improved in the front end of the car and you are also not sacrificing rear wheel and tire width/grip like you would be if you had stock negative camber up front. So the largest benefit if you have camber plates up front is the increase in front end grip and decrease in understeer. If you only have stock negative camber up front than the largest benefit you would see is just the ability to rotate your wheels and tires. As for valve stem measurements we always just go by the stock or oem lengths.
04-04-2013, 02:21 PM | #62 |
380
Rep 4,320
Joe,
The 18x10 with 275/35/18 rear vs. 18x9.5 with 265/35/18… is this just about looks from behind, or is there a slight performance edge? Since in your PM you said they share the same concave face. Also, will I nee extended lug-bolts (or a stud conversion) to handle the new wheels?
04-04-2013, 02:27 PM | #63 | |
1445
Rep 2,662
The 18x10" ET25 with the 275/35/18 in the staggered configuration will provide more rear grip than the 18x9.5" ET35 in the square configuration. The square configured car will have much more balance and feel more neutral as a track set up. The 18x9.5" ET35 in the rear of the Z4M is a conservative fitment but is required when doing the 18x9.5" square set up because any lower of an offset wheel will be much too aggressive of a fitment for the front of the car. Most people will just install a 12mm or larger rear wheel spacer to fill in the fender more for a more flush to the fender and pleasing aesthetic look. You will need either extended lug bolts or a stud kit when ever using wheel spacers.
04-10-2013, 03:10 AM | #64 |
333
Rep 509
Im considering some ACR 8s for my SI Coupe, but I see that you are out of stock of the 9,5x18 ET35 in Hyper Silver. Any idea when they are back in stock?
And are you planning of making a new Group Buy with the ACR 8s?
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
04-10-2013, 04:44 PM | #66 | |
3593
Rep 6,819
Is this on the M? What are your suspension and alignment specifications? That's a pretty aggresssive tire setup in the front and rear! I'd love to see photos of that setup when you have it!
Tags |
18x10, 18x9.5, apex, arc-8, arc8 |
