11-28-2021, 10:02 AM | #45 |
943
Rep 635
11-28-2021, 11:54 PM | #46 | |
115
Rep 288
DrFerry6734.50 |
03-07-2022, 04:57 PM | #48 | |
Friends don't let friends ESS
3224
Rep 888
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
03-07-2022, 09:51 PM | #49 | ||
943
Rep 635
DrFerry6734.50 |
04-25-2022, 08:31 AM | #50 | |
3224
Rep 888
Appreciate this thread so much. I'm refreshing a 100k mile e90 and thinking I will go ahead and pull the trigger on this job. Was wondering your thoughts on replacing the Cam sensors while you're in there. Seems like a good idea - though I don't hear others doing it and no reports of failures. |
04-25-2022, 09:52 AM | #51 | ||
3996
Rep 3,413
Not a Doctor, those are just my initials.
04-25-2022, 08:12 PM | #52 | |
3996
Rep 3,413
04-26-2022, 08:46 PM | #53 | ||
943
Rep 635
04-26-2022, 10:13 PM | #54 |
3996
Rep 3,413
@Vedubin01
"Once secure this is s a good time to replace your spark plugs. This also has a Torque figure of 23 inch lbs." That was preceding the 6Nm call out. Figured it was a typo is all.
04-27-2022, 09:48 AM | #57 | |
943
Rep 635
Spark plugs are 23lbs while the valve cover screws are 6nm. |
spammysammich1627.00 |
04-29-2022, 01:47 AM | #58 |
894
Rep 9,034
Thanks OP.
How much do you charge for to refinish a set of covers? .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-29-2022, 07:19 AM | #59 |
943
Rep 635
04-30-2022, 12:25 PM | #61 | |
31
Rep 64
04-30-2022, 06:40 PM | #62 |
3919
Rep 4,183
Yes that is correct. I bought the full lot and wound up with 2 extra 11157838369 o-rings after the job.
05-03-2022, 08:58 PM | #63 |
31
Rep 64
I ordered Drei Bond through FCP Euro but they sent me BMW Loctite 5970 instead. It also seems to be a RTV sealant. What's the difference between this and Drei Bond and can I use this instead?
https://www.fcpeuro.com/products/bmw...ml-83190404517 |
05-23-2022, 03:04 PM | #64 | |
24
Rep 128
Drives: Le Mans Blue E92 M3
I checked realoem and it should be: x12 11417526315 torx screws (4 for each oil separator = total of 8, 1 for each camshaft position sensor = total of 4) And only x2 instead of x4 for the bigger oil separator seal 11157838369
Instagram: @lmb_m3
05-30-2022, 12:48 PM | #65 |
894
Rep 9,034
1 Drei Bond 07589062376
1 Engine Valve Cover Gasket BMW-11127838271 1 Engine Valve Cover Gasket BMW-11127838272 8 Spark Plug Tube BMW-11127835170 24 Valve Cover Bolt 11127841217, 11127835169 2 valve cover bolts 11127841218 4 Cam Sensor seal 13627796699 4 Cam Sensor bolt 11417526315 2 each Crank Case Vent Seal 11157838369 11157838370 2 Engine Timing Cover Gasket BMW-11127838162 2 oil separator seal BMW-11157838369 Question on the bolts in bold. I just need 24 of either one right? Thanks to everyone who contributed! The price has gone up a LOT at FCP. It's $665 with 12 Torx screws BMW-11417526315 as recommended above. If it's ok to re-use the screws, I'd just reuse my old ones. Are they really one and done? We're not talking rod bearings here. .
05-30-2022, 07:09 PM | #66 |
3919
Rep 4,183
BMW-11417526315 is the cam sensor bolt. You only need 4, not 12.
Not recommended to re-use the valve cover bolts. They have a rubber grommet that hardens with age and can leak oil. |
