Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Can Anyone Explain This Service Writeup?
      09-15-2013, 09:00 AM   #1
Wingman335
Wingman335's Avatar
52
Drives: 2011 335i E92
Hello all,
I recently had the dreaded 'Engine Malfuction- Reduced Power' come on my N55 E92. I had it fixed under warranty, but I am an idiot when it comes to understanding what exactly went wrong.
I am hoping that some mechanically inclined folks here can read the service write up and help me understand what the issue was.
Thanks!
View post on imgur.com
      09-15-2013, 09:15 AM   #2
Blackhawk36
Blackhawk36's Avatar
31
Drives: 2007 335i 6MT No iDrive
He tested for vacuum and pressure leaks. The throttle body is at the bottom of the intake manifold. The charge air pipe (pressurized intake air from the intercooler) slides on the bottom of it and a spring clip holds it on. If it wansn't pushed all the way on when the spring clip is pushed it will eventually vibrate loose.
To visually find vacuum or pressure leaks, they use a smoke generating system and introduce the smoke into the system. If there are leaks, they will see the smoke coming out and can make the repair.
fuel pressure at 5.6 bar means 5.6 times atmospheric pressure of 14.6 psi. That is 81 psi and he is talking about the low pressure pump in fuel tank, not the high pressure fuel pump in the engine.
Hope that helps.
      09-15-2013, 10:33 AM   #3
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
It looks like your charge pipe broke. It is a known weakness, especially if you are tuned and running higher than stock boost pressures.
      09-15-2013, 10:56 AM   #4
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Hope that helps.
+1 to everything.
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI |
      09-15-2013, 12:26 PM   #5
CombatNinja
CombatNinja's Avatar
46
Drives: e91 328i, e90 328i, e90 335i
+1 Charge Pipe let go.
      09-16-2013, 08:17 AM   #6
Wingman335
Wingman335's Avatar
52
Thanks for the replies everyone! I'm surprised that the charge pipe failed- considering that my car has always been stock.
