Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > CXRacing FMIC - Dyno Results
      06-14-2011, 08:30 PM   #1
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
After reading the many Big Tom and CXRacing threads, I decided to install the CXRacing FMIC and do my own tests.
I dyno'd the car with only Vishnu PROcede with the off the shelf v5 maps (13psi peak) on Weds.
I susequently installed the CXRacing FMIC and nothing else, then re-dyno'd 6 days later on the same dyno, same time of day, same temps (90F shop temps). I used a 2.5" piping kit from ebay (comes with silicone couplers, tons of bends, and t-bolt clamps). The kit plus the FMIC was $270 shipped.
As you can see while the peak HP went up 10whp, the area under the curve is different. There is a consistent ~10whp gain from about 5300rpm to redline, with a similar tq gain. There is also a little positive tq hump earlier which I cannot explain. From what I've seen, this is consistent with other name brand FMICs at this power/boost level. I wonder how it would do at 16psi.
*Although the below graphs show 297hp/307hp, the best pulls were 300whp/342wtq with stock IC and 307whp/341 with CX. The runs varied by about 3hp/tq and I compared the two mid ones.
The logs are in this order:
  • Log of stock FMIC Dyno
  • Log of CXRacing FMIX Dyno
  • Log of Road 3rd gear pull with CXRacing FMIC
The fan in the shop is HORRIBLE and is what you can buy at Walmart for $40. True gains on the street should be great. As you can see in the road graph, I typically run a good 2-3 degrees more timing on the road than on the dyno.
I hope this data is useful to the group.
-TG
[edit] Had steel brackets welded to core and bolted to bumper beam. Added pic.
      06-14-2011, 08:34 PM   #2
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
2007 BMW 335i  [8.24]
Good job man, just proves once again if you put the work in its a good small purchase and DIY.
I have exhaust and an intake...
      06-14-2011, 08:39 PM   #3
Alessandro
Alessandro's Avatar
Serbia
111
Drives: Audi RS5
2011 335is  [9.50]
well done thx for sharing
      06-14-2011, 09:03 PM   #4
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Well done!
      06-14-2011, 09:19 PM   #5
mycoupe
55
Drives: 07 335i coupe 6spd
is it just me or do those numbers seem kind of low???
      06-14-2011, 09:25 PM   #6
Booztd 3
Drives: 2007 335i Sedan
I'd take a look at that big mis-fire around 3600rpms.....something isnt right there....
Work: '07 335i Sedan
Play: '90 300ZX (10.3@140mph)
And For Giggles: 06' R1
      06-14-2011, 09:39 PM   #7
MF80
MF80's Avatar
Thailand
45
Drives: AW 2008 E92 335i
Nice! Thanks for taking the time doing this. I was curious about this intercooler awhile back. Really good gain for the price!
      06-14-2011, 09:59 PM   #8
mycoupe
55
looks like an ignition drop of about 6 degrees if you check the second to last graph.
      06-14-2011, 10:33 PM   #9
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
can you post specifically which 2.5 coupler kit you purchased? Thanks.
      06-14-2011, 10:34 PM   #10
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
What should they be? While there is temp/humidity correction, the car still runs less timing on the dyno than the street. I thought 300/342 with chip only was typical, is it not?
Right, dip is there for all of my pre/post runs. If anyone can help explain this, I'd appreciate it.
      06-14-2011, 10:38 PM   #11
Booztd 3
For some reason none of those charts loaded when I initially viewed.
I do see the ignition drop, but directly above it, I also see some (what I believe is) correction in the inverse
I can understand pulling the timing right there at pk tq but that is a pretty drastic ramp rate (which is obvious by observing the tq reading)
      06-14-2011, 10:49 PM   #12
rader1
70
Drives: Cobb Stage 2+ 135i
If its the IC in the first pick next to the stock IC. That's a huge difference size wise, what/how much did you have to cut to get it to fit?
      06-14-2011, 11:06 PM   #13
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
I must be missing the drop.
I've attached two graphs showing the timing details at ~3600rpm, the first with stock IC and the second with upgraded the intercooler (both dynos have the dip, but I included both none the less).
      06-14-2011, 11:11 PM   #14
Joshboody
65
Drives: pickemuptruck
Timing looks good, nothing to worry about. Not sure about the dyno dips... Check the dyne sticky and compare. Could be how the dyno is loaded, vanos. Nothing in the logs would point to this.
OP, you mind if I post an AMS log... I think I can find one with similar ambient, rpm pull, and boost. I'm procede with fmic also. curious how they compare.
      06-14-2011, 11:13 PM   #15
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
That is indeed CX vs. stock. You can't tell once the car is back together, but it is MUCH bigger than stock. The install is the same as the Big Tom IC and the other CX install posts such as THIS ONE
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
      06-14-2011, 11:19 PM   #16
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
If there was knock, how would it show-up in the logs? I'm new to BMWs and how the ECU and PROcede respond to knock (used to reading logs for other cars where there is actually a knock count value to log).
I don't mind at all.
      06-14-2011, 11:26 PM   #17
kdiggz
kdiggz's Avatar
20
Drives: e92 ///M3
Can you describe which hard pipes from the kit you used? Did you have to cut the pipes to make them work? Any fabrication required? Thanks
      06-14-2011, 11:28 PM   #18
Joshboody
65
Cool, I'll look for a comparable log.
Knock is generally a 3deg drop from consecutive sampling points. But make sure you are comparing similar load / boost values. During spool for example there will be a large sudden drop in timing.
We can log knock also, but chances are you will skip the data sample and it won't get recorded. Just like you can't log every rpm. Useless channel.
      06-14-2011, 11:43 PM   #19
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
Essentially, I used onw 90 deg bend for the driver's side to go from IC to factory hard pipe, and a 45 deg for the for the passenger's side to the hard pipe (I did not reuse the factory accordion hose). I had to cut both to fit, but it wasn't hard. You can use a $30 grinder.
There are pictures of other piping setups in the above link.
      06-14-2011, 11:52 PM   #20
Booztd 3
I've only tuned cars with an AEM EMS and we can monitor knock sensor voltages individually (My RB26 powered car has 1 per 3 cylinders)
Naturally the knock sensor will have some noise but usually anything up over 1V I'll interpret as knock.
In the dyno chart below (RB26 car, I wasnt running a tight enough plug gap and the spark blew out, causing that hiccup)
I am curious to see how other dyno's compare....
An abrupt dip of about 30ft/lbs especially at pk tq is definitely not something to ignore...
      06-14-2011, 11:55 PM   #21
Joshboody
65
AMS FMIC Log
Below is a log of 3rd to 4th. It was 100deg during mid afternoon. I had just romped on it after heating up at a stop light, u-turn and stepped on it in 3rd (log shown). About 4000rpm to 6200rpm... i think the OP reved higher to around 6500. My log shows a 124 start of 3rd to 129deg F at the end of 3rd.
OP, what was the ambient temps when you logged the street run? From the log looks like about 34deg C to 42deg?? Typically I see about 15deg F above ambient for IAT when cruising, but there's very little rise in temp during 1 gear WOT.
Boost was around 11psi, but i'm at 1000 ft above sea level, so more like 11.5 to 12psi actually.
did you log wastegate DC by chance... i would be curious since we have similar mods and boost.
EDIT: 91oct shit southwest gas
      06-15-2011, 12:11 AM   #22
The Ghost
Reborn
The Ghost's Avatar
87
Drives: 335i
It was about 78-80 degs F. How did you get it to log in F vs C?
Agreed. I don't know what else to log look for.
