01-12-2024, 09:11 AM | #1 |
154
Rep 422
Aluminum trim -- blade vs. hex?
Opinion question here. My F83 has the carbon trim, and I am thinking of changing it up just for something new to look at. So I am considering swapping in the aluminum trim. I found both the aluminum "blade" (which was an option on the F8x) and the aluminum "hex" (which I believe was an option on the F3x).
I have read that the hex version is more resistant to scratching than the blade version. And it arguably looks better, though that's obviously a matter of opinion. Any thoughts re putting the aluminum hex trim in an F8x, even though it's F3x trim?
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
01-12-2024, 09:59 AM | #3 |
154
Rep 422
I recognize that this is the majority view, but I am not really on team carbon fiber
01-12-2024, 10:19 AM | #4 |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
Aren’t you going to have mismatch? The carbon fiber trim also has black chrome and that’s also on the doors and rear passenger area. Not the CF, just the black chrome trim where the ambient light comes out from.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
tgb1974154.00 |
01-12-2024, 10:29 AM | #5 |
154
Rep 422
Good question -- I will go look. I haven't found a trim set that includes anything for the doors or rear passenger area.
01-12-2024, 10:34 AM | #6 |
154
Rep 422
It looks like the aluminum blade trim has the same black chrome along the bottom, so that would not be a mismatch. There is no CF trim in the rear that I could see. The aluminum hex trim, on the other hand, appears to have gloss black trim along the bottom that would be a mismatch. Awesome catch. Thank you!
01-12-2024, 11:15 AM | #7 |
2468
Rep 5,935
I thought I’d love the aluminum trim so I ordered it on my ‘09 e92 M3. After six months I was tired of it. I find it to be too bright compared to the rest of the interior. Basically, too much contrast. On my ‘12 e92 M3 I ordered the carbon leather trim. I found it to be too dark and non-reflective. So I replaced the trim with the actual oem CF trim and it’s perfect - not too dark and the right amount of reflective-ness. I’ve had the CF trim for 8 years and still love it. I’m certain the same thing would happen with Aluminum trim in the F8x - too much contrast and it’ll always be “screaming” at you. However, I do agree, interior trim is a personal choice. I hope you enjoy the Aluminum trim if you do the swap. FYI, I did a quick search for Aluminum trim and all of the trim I found had this strange dark staining and spotting on the surface, in particular on the largest central dash trim piece. I’d be concerned about this showing up eventually on all Aluminum trim. Perhaps it’s due to a specific cleaning product but you wouldn’t know until it’s too late.
tgb1974154.00 |
01-12-2024, 11:28 AM | #8 | |
154
Rep 422
01-12-2024, 11:48 AM | #9 | |
I like cars
52
Rep 59
Drives: F80 M3
___________________
15 - 328i w/Msport 93 - RX7 Touring 18 - M3 ZCP |
tgb1974154.00 |
01-12-2024, 03:33 PM | #10 |
1431
Rep 1,380
I used to have the aluminum blade trim, swapped it for carbon.
The blade trim is nearly indestructible. You can really feel the weight of it.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
tgb1974154.00 |
01-12-2024, 05:35 PM | #12 | |
13572
Rep 8,190
Door handles are leather so the only trim you would change are on the instrument panel and middle console, and you never touch them. I have the Alu blade. It is just a classic BMW look with the black interior and cold bright trim. It has got a nice texture to it. Looks like new.
tgb1974154.00 |
01-18-2024, 02:56 PM | #14 |
///M
194
Rep 706
Drives: '18 F80 M3 ZCP, '14 F30 328i
In my glacier silver metallic (titansilver) over black leather f30 i went from burl walnut to aluminum hex and in my Alpine White (aplineweiss III) over black merino leather f80 i have the CF.
I opted for the hex because i think it looks way more modern and sporty than the blade. If I were more patient I would have also tried for the blue accent hex trim instead of piano black however, now that I have the hex installed I would choose the piano black since I don't have any other blue accents. I really like the complementary scheme in the f30 and contrast in my f80. I will say that the aluminum hex does show marks pretty easily. It's a little harder to see anything in the darker CF. I am buying up some back up pristine hex interior bits because I really like it and am afraid that I will eventually have to replace some of the door handles due to wear/ tear.
F80 ///M3 '18 S55/ ZCP / executive / 6MT / eventuri CF CAI V2/ CSF TMIC
F30 328i '14 N20 / dinan sport kit / premium pkg / 6MT / hex trim / HK sound / B14 coilovers / oem roof rack / active autowerke exhaust / eventuri CF CAI Last edited by wishbone; 01-18-2024 at 03:06 PM.. |
tgb1974154.00 |
