European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      07-06-2022, 11:36 AM   #1
Fosil Racer
Fossil Racer
Drives: 2015 BMW M4 Coupe
Wheel alignment weights for 2015 BMW M4
There seems to be an abundance of opinions about the amount of static weights needed to be used to properly align the wheels of a BMW. [and other german made cars.] I am particularly interested in the exact weights and proper placements of those for a 2015 F82 [Coupe] M4. NOTE this is about alignment not balancing of the wheels. Be specific about source. Thanks in advance.
Further investigation suggest that Ride height from center of Wheel to Top of Fender opening is the standard and the 2015-2020 M4 and M3 adaptive suspension does not specify a weight loading but rather a ride height for determining and setting wheel alignments. So does Anyone have a ride height Number for the F82?
      07-06-2022, 03:11 PM   #2
BzsBimmer
BzsBimmer's Avatar
3293
Drives: '23 G80 FO M3, M3 & MY Tezzy's
I think OP is asking about something akin to corner balancing process in which weighted load is placed on/in car to represent driver right? Not wheel weights.
      07-06-2022, 04:08 PM   #3
Kilabyte
I'm Batman!
Poland
3949
Drives: Mineral White M3 6MT
I remember e39's needed a certain amount of weight in the trunk for a proper alignment to be done
      07-06-2022, 05:11 PM   #4
Sephrr
Sephrr's Avatar
289
Drives: 2016 M3
I believe a lot of bmw specify to add certain weights in the vehicle to properly do an alignment. I have a hunter aligner at work and can check some to see what it specifies
      07-06-2022, 05:38 PM   #5
x.shell
x.shell's Avatar
6586
Drives: ▋ ▉▉
If you're really a stickler for corner weighting properly and balancing the car for precise track alignment, the "center of wheel to fender" method won't work. Your alignment shop should have the ability to measure out the chassis precisely and use that as the baseline for any adjustments.
Sometimes, subframes are not perfectly mounted onto the frames and further more the fenders aren't ever symmetrically mounted either. For example, according to my alignment guy, the drivers side fender on my car sits an 1/8th inch higher than the passenger fender. So in my case, using the fenders for any kind of ride height assessment was actually off.
All the discussions I've read about "center of wheel to fender" measurements were in regard to the topic of ride height — not alignment.
Not sure if this information was useful to you.
THEROK1273.50
TopJimmy5534.50
      07-08-2022, 01:45 PM   #6
Ant_tc
51
Drives: 2017 BMW M3 30 Jahre
Pics are from a hunter alignment machine.
hC1001610.00
Tags
2015 m4, alignment specifications, f82 coupe
f80post
