07-21-2010, 03:26 PM | #1 |
103
Rep 2,783
Bmw needs to go back to
more simpler times. Key in the ignition, trans and oil dipsticks, and no other electronics, something like windows 7, which is an unbloated vista.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
07-21-2010, 03:35 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
Windows 7 is still Vista, just running more smoothly. If you want unbloated, you need to go back to WinXP
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-21-2010, 03:47 PM | #5 |
vrooommm
11
Rep 145
Drives: 2008 BMW E92 335i
I say: let um put more stuff in... i like gizmos, gadgets and sh*t
BMW E92 - 335i - Spacegrau - Black Dakota - AT - BMW Performance style 313s (19) - BMW Performance suspension - M-aerodynamics - BMW Performance diffuser - considering: BMW Performance exhaust
07-21-2010, 03:53 PM | #6 |
103
Rep 2,783
I started this thread because so many people posts problems with their cars and alot of it has to do with the electronics. The e46 has 1,000 less things that can go wrong with it. I still love the car.
07-21-2010, 03:54 PM | #7 |
103
Rep 2,783
I'll take that too!
07-21-2010, 03:55 PM | #8 | |
General
290
Rep 28,154
trans dipstick is needed too since bmw has faulty auto transmission pan gaskets. |
07-21-2010, 04:51 PM | #9 |
103
Rep 2,783
^They have sensors for tire pressure which you can tell if they are low by looking at it, but then no sensor or dipstick for the transmission? Not only can the pan leak how about the hoses? It doesn't even have to leak a lot, just a little drip every other day.
07-21-2010, 05:06 PM | #10 | |
7
Rep 102
+1 You are not alone... i rather they invest the extra cost on the car on performance related items. sometimes i can't help but think they made all these "enhancements" just so that people will be required to take their cars to the dealership anytime something isn't working properly, and charging an arm and a leg while they are at it. |
07-21-2010, 05:18 PM | #11 |
Not willing to take advice
4109
Rep 1,536
I don't mind having an 'in car check' for the oil, actually like it...but give me a damn dip stick to check whenever it says my oil is low and I know it was fine the previous day.
Proud owner of 4 Turbos and 1 Supercharger
07-21-2010, 05:49 PM | #13 |
119
Rep 2,312
07-21-2010, 06:03 PM | #14 |
Philosopher-king
20
Rep 1,113
Fabric sunroof, one door...
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
07-21-2010, 06:22 PM | #15 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
BMW has two types of customers. Buyers who wants a sports car, and any luxury on top is just cherry. And buyers who wants a luxury car, and any sports on top is just cherry.
They are the two opposing forces at work here. On one hand, the Sporty buyers are the vocal buyers. The influencers. The elitist who all think what they want should be what everyone else gets. They're the type to write to BMW NA in a mass email campaign threatening to boycott BMW if they don't bring the E36 M3 over. They're the ones that tell all their friends and families that they must buy BMWs regardless of their situation and need. However they're the MINORITY. There's probably one sporty buyer for every 10 luxury buyers out there. And BMW knows it. So what do you do, when the VAST majority of your customer base probably don't know what an apex is from a hole in the ground? Simple. You build cars that are bigger, heavier, more luxurious, but with better engine and more technology crammed into the suspension and chassis than anyone has a right to shake a stick at. That way, the sporty buyers are happy that they get a car that handles like no other sedan does, while the luxury buyers get a car with dual comfort climate control that massages your back and shakes your d*ck when you pee. But that formula is not sustainable. With every feature added, and every inch increased and every pound heavier, it takes double the amount of horse power and suspension wizardry to keep the same "performance." So what do you do, again, if you're BMW? Well, formula is simple. You build bigger, faster, and more luxurious cars with more features, and come up with this "magical" entry level 1 series that weighs 200 lbs more than the last generation 3 series and call it the "sportier, lighter" alternative. Unfortunately that hasn't worked as well to BMW's advantage. And the last lightweight, sporty BMW built, BMW sold all but 1,700 units in 3 years, with a $10,000 incentive on top. They just couldn't give it away. So what does that say about BMW's customers again? So for those of you who wish BMW would go back to the "golden" age of building what made BMWs BMWs, those days are long gone. You're better off buying a Porsche. Or a Subaru if you need more practicality. Because BMW stopped building BMWs long time ago. They're now intent on building Lexuses that sort of drive like BMWs. |
07-21-2010, 07:05 PM | #16 |
1086
Rep 1,912
Give me a dipstick. The nice push button starter, electronics, TPMS, Idrive screen, etc. Well, I guess I'll find a way to survive with them.
07-21-2010, 08:52 PM | #17 | ||||
103
Rep 2,783
Yeah, eliminate a spare tire...great move.....i feel safe taking long trips. Quote:
If it was a bmw I would buy it! Quote:
Believe me, you won't even miss them.
07-21-2010, 10:34 PM | #18 |
Retired
19
Rep 868
Drives: Z4 s30i
I had opne of those ! Isetta 300 - door in front... could barely make it up a hill !!! What fun we had. And, oh yes, it was made by BMW !!!
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !! |
07-21-2010, 10:44 PM | #19 |
Philosopher-king
20
Rep 1,113
Yup -- the Isetta IS a BMW! First BMW I ever sat in.
I think I was 5 or 6 at the time.
07-21-2010, 11:15 PM | #20 | ||
42
Rep 1,756
Originally Posted by corneredbeast
An engine from a Z06 Corvette. A differential from a Vespa. Damn Quote:
07-21-2010, 11:17 PM | #21 |
103
Rep 2,783
Nice!!!
07-22-2010, 02:17 AM | #22 |
18
Rep 422
I don't trust the sensor either... I had a MINI Cooper before and the oil light never came on even the oil level was down to less than half... The MINI had a dipstick... I know I was lazy and I never checked because I never had a car which burnt oil before... There was one time I heard some funny noise from the engine and took it to dealer and they topped up 2.5L of oil... The guy asked me how long did I wait after the light was on and I told him the light never came on... from that time on, I checked the dipstick every once in awhile...
2011 1M VO stripper
2009 AW 135i M-sp (sold) 2002 SG MINI Cooper (sold) |
