08-01-2013, 08:52 PM | #1 |
1314
Rep 1,183
Slek Front lip install need help..
I bought this lip and installed with double side tape like the site states.. There are seperations in multipal sections from pressure and one forum member stated that it came off on the hwy... The shop that installed it is going to try using beta link.. My expirience with the rear deck wing was the same.. Tape= take off // beta link = stay...
Has anyone else had this issue with this lip? |
08-01-2013, 10:17 PM | #2 |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
My shop used screws for my front lip.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
08-01-2013, 10:22 PM | #3 |
483
Rep 4,162
Drives: 1/18 Monte Carlo Blue E92 M3
You use both the double sided front tape + screws in the OEM locations for the lip. It won't come off on the HWY unless the installation was botched or you scraped it in the middle and created some type of air pocket.
08-01-2013, 10:24 PM | #5 |
1314
Rep 1,183
It's in the middle. The lip had to be placed by three guys. Ill. Take pics to show ya where
08-01-2013, 10:33 PM | #6 |
483
Rep 4,162
You don't need to drill extra holes. It should have little points where you're supposed to drill them into the lip so that they match up with the OEM mounting points.
08-01-2013, 10:48 PM | #8 |
483
Rep 4,162
Don't remember the count, but it's basically all the OEM mounting points I believe. That plus the double sided tape up front. If you want exact answers just PM the vendor you bought it from.
08-01-2013, 11:19 PM | #9 |
24
Rep 370
Drives: 2011 Jerez Black M3
I had mine installed at SLeK when I picked it up, was the tape and like 8 or 9 screws. You use all the same OEM screws except you will need 2 longer ones but they use all OEM mounting points. NO DRILLING. If you drill you did something wrong.
08-02-2013, 12:10 AM | #11 | |
1314
Rep 1,183
I have not driven it on the hwy yet just the street and thats when the seperating started. I parked it for a few days to let it set too.. |
08-02-2013, 12:13 AM | #12 |
24
Rep 370
If you put the screws in you shouldn't have any issues they should be holding the lip on and the tape is the backup. The only issue I have ever had is I don't fit in the car wash anymore. But no install or anything like this.
08-02-2013, 12:14 AM | #13 |
24
Rep 370
Interesting. I drove home from the shop on the highway and highway drove basically every day since and I'm still good. Are you sure the screws actually hit the OEM holes and are tightened down?
08-02-2013, 12:21 AM | #14 |
1314
Rep 1,183
yup feels solid.. but the double side tape is seperating ... Everyone keeps saying that it will flip down and i'll run it over if there are any air pockets not sealed by the tape....
08-02-2013, 09:24 AM | #15 |
32
Rep 919
The tape you need to use is 3M VHB. Be sure to prep both the paint surface and the rear of the lip with an IPA solution, "bug and tar remover" or mineral spirits to strip off any detailing product or contaminants. Then, heat up the surface a little bit with a heat gun before applying the tape to the paint surface.
Once the tape is on, heat it up again a bit with a heat gun and then push the lip up against it. Hold it there for 30-90 seconds and it should bond just fine. |
08-02-2013, 11:59 AM | #16 |
39
Rep 300
I bought a slek lip used and aborted my first attempt at getting it installed. I also have a Kerscher lip which I might just use instead since it appears to be easier to install. I haven't made up my mind yet.
