      04-12-2012, 06:27 PM   #1
wildcat767676
wildcat767676's Avatar
17
Drives: 2008 BMW 135i Coupe
Ok to use front coil overs with lowering springs rear???
I have JIC Cross coilovers and got sick of the clunking noises in the rear so I swapped back in my H&R springs and stock shocks in just the rear. It rides amazing now but am considering a track day next week. What handling issues would this setup bring forth? Could I run fronts softer to compensate?
Would an M3 sway bar be needed with coil overs and negative camber?
2008 135i AT, iDriveNAV, Remus quad exhaust, A.P. DP/MP/IC, Custom Oil Cooler, BMS JB4/Meth/DCI, JIC Cross Coilovers/Camber Plates/STB, BMWP rotors, EBC Track pads, Motul Fluid, CF Hood, BMWP Kidneys, black painted roof/mirrors, BMWP CF rear spoiler, Roof Spoiler. VMR V710 18" Wheels.
      04-13-2012, 04:43 AM   #2
Sauce
Sauce's Avatar
38
Drives: Montego 135
Honestly i think the only way to answer this question is testing it yourself, go drive it as is if your happy with it. If you haven't noticed any negative effects handling wise yet, you'll be fine.
KW V3's, Sparco Pro2000's, Vorshlag CP's, JB4, Heat Wrapped Raceland DP's, aFe stg. 2 Sealed Intake, Miro 111's, Hankook RS3's 225/245 (for now), Seibon M3 CF Hood, Turner Motorsports Alum. Radiator, Big Tom IC, BMW Performance bumper.
      04-13-2012, 10:00 AM   #3
fourtailpipes
111
Drives: the ladies crazy
from a layout perspective, this should be fine, as we don't get true coilovers in the rear anyway. dynamically it might not work well though, as you'll find that the spring rates and damper settings are not likely a good match.
1addicts
