Spark Plug Change question/buildup
12-13-2011, 08:58 PM | #1 |
26
Rep 318
Updating my plugs and have a question before I proceed, should I clear this "rust" like material out of the spark plug cylinder? If so how should I go about getting it out? Wasn't expecting to find it in there.
Thanks a ton! -Steve |
12-13-2011, 09:02 PM | #3 |
26
Rep 318
Yes I believe it is loose. Seems like some rust was built up on the actual plug. Worried if I try to suck it out or mess with it, it may fall down into the engine. Figured I would ask first before I try to get it out.
12-13-2011, 09:03 PM | #4 |
Cpl D
38
Rep 563
A shop vac should get it out.
What did the plug tips look like??
07 AW e90 335 :jb4/dci/ic/meth= 12.2 @116 :jb4/dci/ic/meth/RaceGas/Slicks/gutted = Broken ET BOARD!
88- Mitsubishi Starion Turbo- Built~My feedback~ http://www.starquestclub.com/forum/i...0&fromsearch=1 |
12-13-2011, 09:05 PM | #5 |
26
Rep 318
First one I pulled. I'll take pics of the rest of them after I'm done. Right in the middle of the install. It was fairly difficult to get out, I think the threads were pretty rusty.
12-13-2011, 11:24 PM | #7 |
26
Rep 318
Sucked the rust right out with a nozzle, all gone.
So I finished up installing the plugs late tonight. Didn't get a chance to drive the car but I did start it up. No check engine lights, but the engine did sound different. Much louder "ticking" noises. I did not put the engine cover back on or close the hood. Could this be just how the engine sounds without all the sound deadening materials? I did give the engine a rev and it felt 10000x better which had me confused because of the engine sound. I have got to believe it is the engine cover not being on. Thoughts? |
12-13-2011, 11:53 PM | #8 |
Cpl D
38
Rep 563
Without the valve cover the ticking noises would be your injectors, and yes they are loud. When I did mine, I did the same thing, and thought the same thing. Once you put that back on it makes a big difference in loudness, so dont worry..
12-14-2011, 07:42 PM | #10 |
Rep 42
Had the same problem with my cylinder closest to the firewall. The rust was around the collar of the plug and the tip was fine except for regular wear. My car has 45k mikles on it.
12-14-2011, 08:12 PM | #11 |
26
Rep 318
Put everything back together all torqued correctly. Before I put it all together engine was still loud. Put the cover on and now it's back to sounding normal.
Also, before I put in the new plugs I was unable to run the cobb accessport without throwing codes in 2 cylinders. I now am able to run the cobb accessport flawless. Feels good to have done the spark plug install myself and now my car feels great. |
12-15-2011, 12:17 AM | #12 | |
16
Rep 93
12-15-2011, 01:28 AM | #13 |
Cpl D
38
Rep 563
Go with the Bosch OEM's....
The dealer plug is a bosch
