06-14-2023, 11:17 AM | #1 |
2523
Rep 1,844
Coolant Flush, do it or skip it?
I haven't been able to get a concrete answer from anyone on this, and I've read/heard both sides of the isle. My car is at about 55k, a 2017 model, I was considering doing a full coolant flush in the fall when I do my next oil change. My coolant has been topped up many times during my ownership, so i'm sure a good portion of it is not 7 years old.
Some people say doing a 60k interval coolant flush is generally good for your car. Others say unless the coolant itself looks bad, or tests below the pH threshold, you shouldn't touch it. I like to do preventative maintenance, I don't necessarily want to constantly test my coolant pH levels, I think keeping new coolant in the system is preferable to marginally passable coolant. I've even seen people say that due to this being a pressurized complex system, it's better to not touch it at all. Anyways, at the end of the day I don't want to waste money doing something that's not needed or recommended, potentially causing more issues than needed. Let me know what you guys think.
06-14-2023, 07:13 PM | #4 |
265
Rep 560
Mine is also a 2017 w/ ~60K mi. and my coolant has also been topped off many times.
I intend to have the cooling system flushed in the fall, with my 60K oil change. 6 years / 60K mi. is a reasonable service life for coolant. I had my transmission fluid/filter/pan done at 5 years / 50K mi. Again, reasonable service life. Relatively cheap insurance if you intend to keep the car.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
06-14-2023, 07:20 PM | #5 | |
2523
Rep 1,844
06-14-2023, 08:57 PM | #6 |
68
Rep 329
its real easy to DIY. 2 Hoses one connecting to rad , and other heat exchanger. Let them both drain out.. get Distilled water , and bmw coolant ,, fill back up half water / coolant. Look up bleeding procedure , very simple maintenance or you can go to a shop and pay 200$ lol
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
06-14-2023, 09:00 PM | #7 | |
2523
Rep 1,844
06-15-2023, 08:51 AM | #8 |
Armchair Aristocrat
344
Rep 444
A coolant flush is one of the only services I would pay for because, unlike motor or transmission oil or even brake fluid, doing coolant flushes yourself often involves it spilling copiously on your hands or the ground. No thanks.
B58 parts491.50 |
06-15-2023, 09:03 AM | #9 | |
2523
Rep 1,844
06-15-2023, 11:29 AM | #11 |
Cheapskate
4464
Rep 4,995
I vote skip, but that's just me personally. You are not going to get all of the coolant out of both systems anyway. A good chunk of it is trapped at the bottom of the radiator and we don't have a proper drain point that is low in the system.
06-22-2023, 03:10 PM | #12 | |
265
Rep 560
Wouldn't the dealer or a well equipped & educated shop do a 'flush and fill', not just a drain and fill?
06-22-2023, 09:11 PM | #13 | |
492
Rep 806
Last time I used my recycle bin, it was almost big enough. A big sheet of cardboard on the floor, nitrile gloves, hat. A 6'x6' pan would be good. How about a drain valve, like Honda has. Despite all that, it still was all over the floor, and all over me by the end. My water pump is leaking. That will be 3 times touching coolant in 9 months. Punctured front rad in October, hose blew off out of nowhere during casual driving late March, and now leaking pump/replace entire cooling system. Siphoning what you can out of the tank and leaving it factory sealed as long as possible could be the way. Plastic junk. Last edited by B58 parts; 06-22-2023 at 09:17 PM.. |
06-24-2023, 02:20 PM | #14 |
DisplacementReplacement
440
Rep 1,131
i just had it done along with a lot of other things including a water pump and i'm at 59k... i'll do it every 60k... makes sense to me.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
06-25-2023, 10:31 AM | #15 |
2089
Rep 2,651
I had the dealer do mine though they didn't do the air to water intercooler reservoir.
It cost about 260$ for the drain and fill (including parts and labour) Surprisingly cheap for dealer stuff.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
06-28-2023, 10:40 AM | #16 | |
Cheapskate
4464
Rep 4,995
They don't even design our systems to be fully drained anymore. Unless you have contamination I struggle with this one, but it's not something that'll necessarily hurt. As long as you bleed it properly. |
PeterWT264.50 |
06-28-2023, 03:40 PM | #17 |
4554
Rep 5,413
Drives: 2015 BMW 335i x-Drive Auto
If you change your coolant, research first and also change any known problems in the cooling system. For example the N55 plastic Mickey Mouse fitting is known to break so I replaced it with an aluminum upgraded fitting along with a new hose. Also the top coolant return line has a plastic fitting that eventually breaks. It can’t be upgraded so I just have it on my list of regular maintenance items to proactively replace before they break.
Every engine has items like these that are worth proactive replacement . |
06-28-2023, 05:25 PM | #18 |
Armchair Aristocrat
344
Rep 444
Two proactive replacements for my 340i manual transmission are replacing the cheap plastic clutch fork pivot pin with a brass version and replacing the soft metal rotor set screws with stainless steel versions.
06-28-2023, 07:51 PM | #19 |
1671
Rep 4,933
I'm with Kern417 on this one. In a previous lifetime, cast iron blocks used to rust and start to contaminate the fluid. With aluminum and plastic, I struggle with what actual goes wrong over time (coupled with it's impossible to replace all of it).
kern4174464.00 |
06-28-2023, 07:56 PM | #20 | |
2523
Rep 1,844
this thread did basically confirm my notion from reaearch i’ve done, there’s no good answer to this dilemma. it seems just as a matter of opinion.
06-29-2023, 08:55 AM | #21 | |
1671
Rep 4,933
The car does burp and suck coolant from the expansion tank, so that should be very close to what the rest of the system sees from a mixture standpoint. I'd just wouldn't add straight coolant or water to that tank. |
toxik2522.50 |
06-29-2023, 08:58 AM | #22 | |
2523
Rep 1,844
Wires1670.50 |
