corner balancing
12-03-2013, 09:08 AM | #1 |
82
Rep 725
corner balancing
is it worth it ? having my car done this Thursday and wonder what your opinion's are on it.
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
12-03-2013, 09:37 AM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
If you had to ask, it's not worth it.
How often do you take your car to the track?
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
12-03-2013, 12:14 PM | #3 | |
146
Rep 1,160
Yes - if you know what to do with it and can adjust your suspension. For public roads, satisfies curiosity, at least. Maybe reveals an issue that can be adj'd out. Maybe not! |
12-03-2013, 08:49 PM | #4 |
82
Rep 725
obviously having it done so I personally think its worth it. I just wanted others opinions if they felt spending the extra money having the corner balancing done was worth it to them and did it make a significant difference in the characteristics of the car as a daily driver/street car . have I tracked it no unless you want to count 40 to 50 times down the 1/4 mile do I plan to yes absolutely will be there this summer. that being said just wanted someone with experience in either doing it or having it done in the past and what they thought .
12-03-2013, 10:21 PM | #5 |
1567
Rep 4,110
Drives: BMW M3
Realize that your car will not sit 'even' after corner balancing since it's accomplished by adjusting the ride height at each corner.
I've had it done to my car but I take my car to road courses; it helps keep tire performance consistent.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
12-03-2013, 11:31 PM | #6 |
82
Rep 725
was one of my biggest concerns .don't think I would like it if it was a noticeable difference . I have heard of people having it done and the wheel gap was way off around the car
12-04-2013, 10:29 AM | #7 | |
1821
Rep 5,337
When I had my car corner balanced, all they did was turn one of the front collars by ~1.5 turns. That moved the corner up less than 1/16". Once the car is on the ground, it is impossible to tell that the gap isn't "even." Now, based on what you said? It's not worth it. The biggest effect on corner balancing for me, was after each 25 minute session on a road course, I can measure my tire pressure and tire temp and they're all nearly identical, which means the car is using all 4 tires evenly, which leads to a more balanced handling and better lap times. Since the CB is done right after the coil-over install, I can't tell you how big of a difference it made. But judging from the tire temp and pressure data, it's worth it for me. But if you've never taken the car to a road course, and are "planning" on going in the future? Don't bother. You won't be able to take advantage of nearly 60% of what the car is capable of doing, and that last 10% of handling "prowess" corner balancing will add won't be appreciated at your skill level. Like I said. If you had to ask, don't bother.
12-04-2013, 09:27 PM | #8 | |
82
Rep 725
12-05-2013, 10:43 AM | #9 | |
2006 330i, TSM, Black, manual, sport
882
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
As The Hack said, I don't think it's worth your while since you don't track your car.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
12-05-2013, 11:29 AM | #10 |
45
Rep 345
Drives: Many BMW's & Porsche's
Typically, when we install a suspension we do NOT corner balance. BMW's are so well balanced to begin with, that if you set the ride height correctly during the coilover installation, that is should be 85-95% corner balanced already.
We only corner balance if the customer specifically asks us to. On our own cars that we take to the track, we do not corner balance them. So, if you set the rider height correctly, you should be good and I would say save your money. |
12-05-2013, 08:35 PM | #11 |
82
Rep 725
thanks for all the input guy's, dropped off car today and picking up tomorrow. spent some time discussing this with the shop and they said the same thing that its probably not worth it but since they are doing the set up of the suspension anyway told them to go ahead and do it since the cost of setting it up with the alignment was not much different than the corner balancing .guess in the long run at least I know its set up correctly .
the shop asked my weight and said they would be adding the 200lbs to the drivers seat and I made sure I had a 1/2 tank of fuel due to the fact I thought that was a happy medium for fuel weight .
12-06-2013, 04:03 PM | #12 | |
Supreme Allied Commander
3890
Rep 54,597
Drives: F80 M3
I only started to corner balance my car after 1) got serious about tracking 2) spring swap 3) major weight shavings 3) new coils. Other than that for a street car it really isn't worth it. I also have my suspension pretty dialed in so the corner balancing is somewhat necessary, as Dan said, to keep consistency. -Mike |
12-12-2013, 03:09 PM | #13 | |
41
Rep 642
Bring up the right wing too much and the left nose ......crinkles. Not a good thing.Adjusting the right nose is not the solution. I am sure it plays out very similar on cars, but it easier to be lazy. |
12-12-2013, 04:03 PM | #14 | |
1821
Rep 5,337
I can tell you for sure that after corner balancing, the left != the right. See corner balancing sheet below. My car was set-up to include a 225lbs driver and a 180lbs passenger. The cross weight came within 7 lbs, 1,801 vs. 1,808. But the side to side difference is 19 lbs, 1,795 vs. 1,814 (the left is heavier when the car is static).
12-12-2013, 06:09 PM | #15 | |
41
Rep 642
