07-31-2017, 03:30 AM | #1 |
13398
Rep 7,484
Some fault codes... any help appreciated!
Read with Carly but will connect Rheingold this evening:
3. Immobilizer System: <---------------------------> Body Domain Controller : - Fault: Welcome Light-repeat active - Code: 8041A8 5. Systems: <---------------------------> Infotainment: - Fault: MOST: not wake up ring - Code: E1C444 7. Body: <---------------------------> Automatisches Front Steering: - ECU not present/no answer <---------------------------> Rear Electronics Module / Elektronik Modul hinten: ECU OK, no fault code <---------------------------> Integrated Chassis Management Quer/Längsdynamik: - Fault: With greater uncertainty direction Vx 2 M/S- Sbs function - Code: 480134 8. Motor Control: <---------------------------> Advanced Crash and Safety Management (ACSM): - Fault: sorry, unknown DTC fault - Code: 930BB9 Central Gateway / zentrales Gateway: - Fault: :Synchronization failed - Code: CD0487 ABS + DSC: - Fault: :Because of the cost over-temperature shutdown - Code: 801A55 <---------------------------> Gear switch / Gangschalter: ECU OK, no fault code <---------------------------> High beam / Fernlicht: ECU OK, no fault code <---------------------------> Instrument cluster / Kombiinstrument: - Fault: :Not receive complete show list - Code: E12C40 <---------------------------> Driver seat /Sitz Fahrer Heck: - Fault: sorry, unknown DTC fault - Code: 802A1E <---------------------------> Seat passenger/ Beifahrer Sitz: ECU OK, no fault code <---------------------------> HiFi: ECU OK, no fault code <---------------------------> Air conditioning / Klimaanlage: - Fault: :Internal component failure PTC module - Code: 8011F9 - Fault: sorry, unknown DTC fault - Code: E71470 - Fault: sorry, unknown DTC fault - Code: E71472 Thank you in advance. |
