04-26-2008, 04:39 AM | #1 |
Rep 27
Rubbing with 19" rims
i put a set of 19" rims on my convertible 1 series (M pack), its fine with regular driving. but when ever i go over speed humps i have to brake to under 5mph or i get rubbing on the wheel arches when the wheels bang upwards due to the hump. is there any solution to this ?
i could have the arches rolled out although this may ruin the look of the car??? i could have the car raised 1 inch, but will this ruin the M suspension i had to pay extra for or the ride quality drastically??? i could buy a set of tyres with a lower profile than the ones i currently have on, but will that make any difference??? thanks for you feedback |
04-26-2008, 06:07 AM | #4 |
Rep 19
A 36HH rack on a chick doesn't work/look right for the same reason a 19" wheel (with probably the wrong offset) doesn't work/look right on a 1 series. I call it 'Proportion'.
With that said, you can try a lower profile tire as well as stretching a less wide tire on the rim. I would try to sell/return those 19"s though, as those sized wheels are actually 'ruining' performance on your car. ...Tommy |
04-26-2008, 07:24 AM | #6 |
73
Rep 2,387
If you really want to keep the 19's, get a lower profile tire.
What size tires are you using on the 19's ? Rolling the fenders shouldn't change the look of the car. Do the tires stick out with the offset your using, or are they tucked in more? Personally I will leave the 264's on my 135i. They look great, and they are designed for the car. Plus they are probably pretty strong even though they aren't forged. |
04-26-2008, 08:55 AM | #9 | |
73
Rep 2,387
I would maybe suggest a 225/35/19 in front and a 255/30/19 in the rear. If you want the same all around maybe 235/30/19, 225/30/19 |
04-26-2008, 08:58 AM | #10 |
Rep 153
Sounds like you rear offset is too high. How much space do you have between the back of the rear wheels and the shock? Pictures would be worth 1000 words. Nate
04-26-2008, 09:20 AM | #11 |
Santa Fe Concorso
104
Rep 2,984
Yes, more information is needed. First, what is the offset of the wheels? Where, exactly is it rubbing? The fender liners on the 1-Series seem to intrude into the fenderwell more than on some cars. And as previuosly noted close-up pics where the rubbing is occuring would be very helpful.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
04-26-2008, 02:13 PM | #12 |
Rep 27
i fixed the problem the edge of the tyres was hitting the inside edge of the wheel arches.
so i change the tyres to ones with a more curve edge, than the square edged ones before. now it runs fine on 19's and i can even go over speed humps at 35mph with no rubbing or banging |
04-26-2008, 02:31 PM | #13 | |
73
Rep 2,387
PICTURES PLEASE Congrats on solving your problem. |
04-26-2008, 02:36 PM | #14 |
Santa Fe Concorso
104
Rep 2,984
04-27-2008, 06:34 AM | #17 |
The ONE
Rep 388
that looks awefully hard to keep clean, but it goes with your black
135i Cabriolet | Sparkling Graphite Metallic | Coral Red Boston Leather | Moonlight top | Glacier Aluminum trim | Premium package | M Sport package | Sound package | PDC | Power Seats
