JB4 Map 2, DCI, RR Catless DP's & Muffler Delete..**LOGS inside** Need comments...
12-18-2011, 05:38 PM | #1 |
49
Rep 770
Just threw my RR Catless DP's on today..did some data logging for good measure..but the car is running great, pulling hard as ever..let me know what you experts think. Im not gonna pretend to understand half this shit
12-18-2011, 09:56 PM | #2 |
245
Rep 4,936
your IGN adv is dropping way to low at the top of each gear for the boost your running . You either need meth/race gas or lower the boost.
You want to be at 10+ above 3-4k rpms. Post this over on n54 tech. Terry could help will help you much better then any of us.
[SIGPIC][/SIGPIC]
12-19-2011, 11:00 AM | #3 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
What octane gas are you using?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
12-19-2011, 12:04 PM | #6 |
245
Rep 4,936
you need methanol or set to map 5 or map 1. 15+ psi is a no no with no fuel enhancement.
[SIGPIC][/SIGPIC]
12-19-2011, 12:25 PM | #8 |
178
Rep 6,631
Your afrs are downright scary your ignition timing looks terrible and please provide a full datalog winding out the gears (at least a 3-4 shift) so we can see how the car performs under load.
You may want to invest in the CPS module from BMS for the timing drops. For $85 it's a worthwhile investment. Contact Terry for help with your afrs as that looks terrible.
E90 LCI N54 6AT
12-19-2011, 12:28 PM | #9 | |
245
Rep 4,936
better with meth. Keeps the motor healthy and ign happy to. At the end of the day you want ign adv to be 10 degrees or above pst 3500-4000 rpms and then start to slowly climb. If your Ign adv is bouncing around 1 of 2 things are off. Too much boost or not enough octane.
[SIGPIC][/SIGPIC]
12-19-2011, 12:37 PM | #10 |
Joint Chiefs of Staff
4927
Rep 116,037
AFRs look fine for 9/16 firmware, as programmed. There is a timing drop there but it's not the end of the world. 6-7 degrees of advance at 5000rpm is where it should be for those conditions. The car is running fine. With that cold weather I'm sure it feels like a rocket.
Mike |
12-19-2011, 12:43 PM | #11 |
178
Rep 6,631
Scratch that those top logs are worthless part throttle logs where afr is normal. Still a bit lean under WOT but that last log isn't nearly as bad.
I'd still get the CPS module to prevent the timing drops.
E90 LCI N54 6AT
12-19-2011, 12:45 PM | #12 |
15
Rep 210
Does CPS work with 93 octane? I thought it was for lower octane setups.
12-19-2011, 12:57 PM | #13 |
178
Rep 6,631
CPS works for all fuel types. The stock timing curve is simply too aggressive for these elevated boost levels. Might not be "necessary" but your engine will surely be happier.
E90 LCI N54 6AT
